Buy & Sell: Others
Gas detector, เครื่องวัดแก๊ส Gas leak detector เครื่องตรวจแก๊สรั่ว Gas detector
3
4
5
6
8
หัวข้อ: Gas detector, เครื่องวัดแก๊ส Gas leak detector เครื่องตรวจแก๊สรั่ว Gas detector (อ่าน 5775 ครั้ง)
aventure1
กระทู้: 1,965
มกราคม 30, 2022, 02:17:31 AM »
Gas detector,
Single Gas Detector Multi Gas Detector
Fixed Gas Detector PID VOC, Gas Detectors Disposable
Gas Detector Area Gas Monitors Accessories & Spares
Single Gas, Detector Honeywell BW Solo,
Single Gas:, BW Gas Alert Extreme, Single Gas:,
Crowcon Gasman, Single Gas:, Gas Badge Pro
คืออุปกรณ์ที่ตรวจวัดตัวของแก็ส เพื่อความปลอดภัยในการปฎิบัติงาน
Bringing new visibility, reliability and ease of use to gas detection in semiconductor processing and industrial manufacturing. Product Overview: The Midas Gas Detector uses reliable sensor technology to detect many key toxic, ambient and flammable gases in a plant. The device monitors points up to 100 feet (30 meters) away while using patented technology to regulate flow rates and ensure error-free gas detection. Thanks to Honeywells use of advanced robotics, the Midas Gas Detector offers unbeatable quality and reliability: Improved visibility and ease of use. The Midas Gas Detector is equipped with bright LED lights and an intuitive, interactive interface that provides instant alerts to gas readings or alarm levels. The interface also includes password-protected menus for configuration, test and calibration. Easy installation. Compact in size with an easy-to-handle metal chassis, the Midas Gas Detector is simple to install. Thats especially important in crowded, complex process environments where space is at a premium. Numerous applications. With feature-rich capabilities that are easy to use, the Midas Gas Detector is suitable for many industry applications, including semiconductor processing, light industrial manufacturing, university laboratories, aerospace, wastewater and more
Install Honeywell 301IRF sensor at low levels in chiller room for reliable detection of a variety of refrigerant gasses. Requires installation with a 301EM-20 controller. Product Overview: Discreet design and rugged ABS-Polycarbonate housing for the 301IRFS set the standard for at the source gas detection in a chiller room. Mount directly to the chiller pad or low on the wall in close proximity to achieve early notifications in the event of a refrigerant leak.
ASHRAE No 15-2001 Mechanical Standard and B-52 Code Compliance The ASHRAE and B-52 security standards have been established to minimize risk and protect the safety of mechanical room personnel and the environment at large. Honeywells 301IRF, together with the 301EM mechanical room controller, provides a complete solution that meets and even exceeds these rigorous standards. The 301EM can be configured to offer automatic fan, horn and strobe activation in addition to manual fan activation when the 301IRF detects a refrigerant.
Portables IntelliDoX
Product Overview: With the IntelliDoX instrument management system, simply place a detector in the docking module, and it automatically performs certain activities based on your specifications in the Fleet Manager II or Honeywell Safety Suite software. You can set each module to do a bump test, reconfigure the detectors high and low alarm set points, and more. Also use the software to analyze the data from each gas detector, run reports, track compliance and even send email reminders to workers.
Sensepoint XRL is a fixed point gas detector with Bluetooth that allows the user to connect the gas detector to a smartphone or tablet running the Sensepoint gas detector app. Sensepoint XRL is available as a flammable gas detector for the detection of potentially explosive gases, or as a toxic gas detector for the detection of a range of toxic gas hazards commonly found in industrial applications. Winner of both iF and Red Dot design awards, Sensepoint XRL is designed with simple and quick installation in mind. And for initial calibration, all you need is our Sensepoint App on your smartphone and a cylinder of calibration gas no need for walkie-talkie guidance with the control room. Use the Sensepoint App to create a profile for the detector, choose alarm set points, run test procedures and automatically generate a commissioning report, which you can send from your phone to other stakeholders or store for easy access in a safety inspection. No need for paperwork.
Industrial Fixed: Signalpoint Flammable and Toxic Gas Detector
Toxic and Oxygen detectors are designed for use in non-explosive atmospheres. They are 2 wire 4-20mA loop powered and can be used with PLC or dedicated gas control systems. Toxic and Oxygen versions of Signalpoint also provide a local LED indication of their status: periodic green flash (OK), flashing amber (warning) and flashing red (alarm). Seconds count and so the front-end sensor design ensures fast speed of response even with sticky gases.
ATEX certified flammable, toxic and oxygen gas detectors that offer a high-quality, low-cost solution to monitoring hazardous areas. Product Overview: The Sensepoint range of flammable, toxic and Oxygen gas detectors offer users a high quality, low cost solution to their industrial gas monitoring needs. Installation in potentially explosive atmospheres is made by the use of a suitable Exd or Exe approved junction box. The industry standard outputs from Sensepoint are connected to either a choice of Honeywell Analytics controllers or 3rd party DCS / PLC systems. Both flammable and toxic versions are certified to the latest European ATEX safety and performance standards.
The flammable detector is available in either % LEL or PPM detection range versions and provides an industry standard mV bridge output. Typical life expectancy is greater than 5 years, after which the detector is simply replaced with a new one. The toxic detectors are supplied pre calibrated for easy installation and provide an industry standard 2 wire 4-20mA loop output. User connections are Exd, while front end Intrinsic Safety (IS) design allows for easy exchange of the replaceable sensor while powered. IS design also removes the need for a sinter enabling very fast speed of response and detection of sticky gases such as Chlorine and Ammonia. Sensepoint has proven its suitability across a wide range of demanding applications by delivering high performance and reliability at an affordable cost.
Toxic and combustible gas detectors use electrochemical and catalytic bead sensors which are designed to be highly sensitive to specific hazardous gases. The performance of these sensors can be affected by the presence of other chemical compounds, such as those found in some cleaning and antiseptic products. Using such products to clean or disinfect gas detectors may cause temporary or permanent changes in the sensitivity of a sensor.
Customers should avoid sanitizing detectors with cleaning agents which include the following active ingredients: Alcohol, including products such as Purell® and Lysol® or Lysol wipes Sodium hypochlorite (bleach), including products such as Clorox® or Clorox wipes D-limonene, including products such as Dawn® or Sunlight® dishwashing liquid Silicone, including products such as Armor-All® or Armor-All wipes Customers using products with these ingredients at their site should ensure that additional care is taken when handling gas detectors and their sensors. If possible, antiseptic products should be removed from all areas where gas detectors are used and stored.
Gas Sensors 7 Series
High Tech & Semiconductor Midas®-M Fixed extractive, 4-in-1 multi gas detector
Features & Benefits: Over *33 gases available with 2 year warranty : 17 gases available at launch 4-in-1 multi smart sensor cartridge with on board * e-calibration certificate Modular design for easy to use and service (front, pump, sensor cartridge, main and base) 3 built in relays (Form C) for Alarm 1, 2 and Fault Power over Ethernet (PoE) communication Keypad interface and remote web browser interface Factory-calibrated sensors to reduce need for frequent gas testing Isolated 0-21 mA analog output with fault and event reporting Modbus/TCP Ethernet for easy connectivity to all control and alarm systems ports for control connectivity and service interaction Robust extractive pump system (2 year lifetime) sampling up to 100 feet
Gas detector, Single Gas Detector
Crowcon Gasman
Gas Badge Pro
คุณ พีระพัฒน์ Tel:
086-902-4999
บริษัท พีพีเซฟตี้ จำกัด
3 ซ.สวนสยาม 1 แขวงคันนายาว
เขตคันนายาว กรุงเทพ 10230
Tel:
086-902-4999
Fax:
02-136-2177
E-mail:
info@ppsafety.co.th
http://www.ppsafety.co.th
Keyword:
Gas detector
aventure1
กระทู้: 1,965
Re: Gas detector, เครื่องวัดแก๊ส Gas leak detector เครื่องตรวจแก๊สรั่ว Gas detector
มกราคม 31, 2022, 01:48:14 PM »
ขออนุญาต อัพเดทกระทู้
aventure1
กระทู้: 1,965
มกราคม 31, 2022, 10:36:08 PM »
aventure1
กระทู้: 1,965
กุมภาพันธ์ 01, 2022, 11:23:24 AM »
aventure1
กระทู้: 1,965
กุมภาพันธ์ 01, 2022, 03:21:01 PM »
aventure1
กระทู้: 1,965
ตอบกลับ #5 เมื่อ:
กุมภาพันธ์ 01, 2022, 06:33:45 PM »
aventure1
กระทู้: 1,965
ตอบกลับ #6 เมื่อ:
กุมภาพันธ์ 02, 2022, 12:01:46 AM »
aventure1
กระทู้: 1,965
ตอบกลับ #7 เมื่อ:
กุมภาพันธ์ 02, 2022, 10:38:03 AM »
aventure1
กระทู้: 1,965
ตอบกลับ #8 เมื่อ:
กุมภาพันธ์ 02, 2022, 01:00:32 PM »
aventure1
กระทู้: 1,965
ตอบกลับ #9 เมื่อ:
กุมภาพันธ์ 02, 2022, 06:14:37 PM »
aventure1
กระทู้: 1,965
ตอบกลับ #10 เมื่อ:
กุมภาพันธ์ 02, 2022, 08:39:25 PM »
aventure1
กระทู้: 1,965
ตอบกลับ #11 เมื่อ:
กุมภาพันธ์ 02, 2022, 11:23:23 PM »
aventure1
กระทู้: 1,965
ตอบกลับ #12 เมื่อ:
กุมภาพันธ์ 03, 2022, 10:17:19 AM »
aventure1
กระทู้: 1,965
ตอบกลับ #13 เมื่อ:
กุมภาพันธ์ 03, 2022, 03:11:27 PM »
aventure1
กระทู้: 1,965
ตอบกลับ #14 เมื่อ:
กุมภาพันธ์ 03, 2022, 05:42:49 PM »
Gas detector,
Single Gas Detector Multi Gas Detector ..
Gas leak detector, Gas detector, เครื่องตรวจแก๊สรั่ว เครื่องวัดแก๊ส.
คุณ พีระพัฒน์ Tel:
086-902-4999
Tel:
086-902-4999
Fax:
02-136-2177
E-mail:
info@ppsafety.co.th
Keyword:
Gas detector
3
4
5
6
8
Buy & Sell: Others
