ผู้เขียน หัวข้อ: ข้อมูลจำเพาะ GC เดิมๆ V1-V6  (อ่าน 5490 ครั้ง)
« เมื่อ: ตุลาคม 31, 2010, 10:51:32 pm »
พอดีไปเจอมาครับ เอามาฝากกัน creditนะครับ
: http://www.subaru-impreza.org/forum/technical-general/75415-jdm-classic-sti-specs.html
STi (*Ver.I)
Launch Date: 1/1994 Price: 2,778,000 yen
Applied model code: GC8B48D
SPECIFICATIONS
ENGINE
Engine Type ....................... 1994cc, water cooled, DOHC 16V, Closed deck block.
Engine Code ...................... EJ20GDW1HD
Rev Limit ............................ 7000rpm
Turbo ................................. TDO5H
Injectors ............................ 470cc
Bore/Stroke ....................... 92.0x75.0
Compression Ratio ............ 8.5
Max. Power Output ........... 250ps/6000rpm
Max Torque ....................... 31.5Kgm/5000rpm
0-60
Max Speed ........................ 180 km h (restricted)
SUSPENSION & STEERING
Front Axle ......................... McPherson Strut
Rear Axle .......................... Strut
Steering ........................... Power assisted rack and pinion.
Front Brakes .................... 15” 2 pot Ventilated Disks
Rotor Size ........................ 277x24
Rear Brakes ..................... 14” 1 pot Ventilated Disks
Rotor Size ........................ 266x18
Wheel Size ...................... 15x6.0JJ+55
Tyre Size ......................... 205/55R15
DRIVE TRAIN
Type................................. Full time AWD, Viscous Coupling
Transmission Type .......... 5MT
Transmission Code ......... TY752VB3CA
Transmission Ratios........ 1st 3.454
2nd 2.062
3rd 1.448
4th 1.088
5th 0.825
Reverse 3.416
Final drive 4.111
DIMENSIONS
Overall Length ............... 4340mm
Overall Width ................. 1690mm
Overall Height ................ 1405mm
Wheelbase .....................2520mm
Front Track ..................... 1465mm
Rear Track ...................... 1455mm
Weight ........................... 1180kg
COLOURS**
Feather White #30
Light Silver Metallic #62
Vivian Red #36
Black Mica #52
* The First incarnation of the STi had no version moniker attached to it, it was simply known at the "WRX STi". It also had no red top manifold.
WRX A
Launch Date: 1/11/1992 Price: 2,298,000 yen
Applied model code: GC8A48D
SPECIFICATIONS
ENGINE
Max. Power Output ........... 240ps/6000rpm
Max Torque ....................... 31.0Kgm/5000rpm
0-60
DRIVE TRAIN
Transmission Code ......... TY752VB3AA
2nd 2.062
3rd 1.448
4th 1.088
5th 0.825
Reverse 3.416
Final drive 4.111
DIMENSIONS
Weight ........................... 1200kg
COLOURS*
Feather White #30
Vivian Red #36
Black Mica #52
« แก้ไขครั้งสุดท้าย: ตุลาคม 31, 2010, 11:21:22 pm โดย name_joker »
Re: ข้อมูลจำเพาะ GC เดิมๆ V1-V6
« ตอบกลับ #1 เมื่อ: ตุลาคม 31, 2010, 10:52:29 pm »
STi Ver. II
Launch Date: 8/1995 Price: 2,748,000 yen
Applied model code: GC8D4ED
SPECIFICATIONS
ENGINE
Engine Type ....................... 1994cc, water cooled, DOHC 16V, Open Deck block.
Engine Code ...................... EJ20GDW5PE
Rev Limit ........................... 7000rpm
Turbo .................................. TDO5H
Injectors .............................. 470cc
Bore/Stroke ........................ 92.0x75.0
Compression Ratio ............. 8.5
Max. Power Output ........... 275ps/6500rpm
Max Torque ....................... 32.5Kgm/4000rpm
0-60
Steering ............................. Power assisted rack and pinion.
Front Brakes ..................... 15” 2 pot Ventilated Disks
Rear Brakes ...................... 14” 1 pot Ventilated Disks
Rotor Size ......................... 266x18
ABS .................................. Optional
Wheel Size ........................ 16x6.5JJ
Tyre Size ........................... 205/50R16
DRIVE TRAIN
Type................................... Full time AWD, Viscous Coupling
Transmission Type ............ 5MT
Transmission Code ........... TY752VBAAA
Transmission Ratios.......... 1st 3.454
2nd 2.062
3rd 1.448
4th 1.088
5th 0.825
Reverse 3.416
Final drive 4.111
DIMENSIONS
Overall Length .................. 4340mm
Overall Width .................... 1690mm
Overall Height ................... 1405mm
Wheelbase .......................... 2520mm
Front Track ........................ 1465mm
Rear Track ......................... 1455mm
Weight ................................ 1200kg
COLOURS*
Feather White #30
Light Silver Metallic #06
Active Red #59
Black Mica #7A
Cosmic Blue Mica #16
WRX B
Launch Date: 9/10/1993 Price: 2,298,000 yen
SPECIFICATIONS
ENGINE
Engine Code ...................... EJ20GDWIHD
0-60
Wheel Size ........................ 15x6.0JJ+55
Tyre Size ........................... 205/55R15
DRIVE TRAIN
Transmission Type ............ 5MT/4AT
Transmission Code ........... TY752VB3CA/TZ102YB3AA
2nd 2.062
3rd 1.448
4th 1.088
5th 0.825
Reverse 3.416
Final drive 4.111
DIMENSION
Weight ................................ 1250kg
COLOURS*
Feather White #30
Vivian Red #36
Black Mica #7A
« แก้ไขครั้งสุดท้าย: ตุลาคม 31, 2010, 11:23:06 pm โดย name_joker »
« ตอบกลับ #2 เมื่อ: ตุลาคม 31, 2010, 10:53:35 pm »
STi Ver. III
Launch Date: 9/1996 Price: 2,885,000 yen
Applied model code: GCD84ED
SPECIFICATIONS
ENGINE
Engine Type ....................... 1994cc, water cooled, DOHC 16V, Open Deck, Boxer-Master IV block, Boxer Master 4.
Engine Code ...................... EJ20KDW6PR
Rev Limit ............................ 7900rpm
Turbo ................................. RHF5HB
Compression Ratio ............ 8.0
Max. Power Output ........... 280ps/6500rpm
Max Torque ....................... 35.0Kgm/4000rpm
0-60
Steering ............................ Power assisted rack and pinion.
Front Brakes ..................... 16” 4 pot Ventilated Disks
Rotor Size ......................... 294x24
ABS ................................... 4 Channel ABS
Wheel Size ........................ 16x7JJ
DRIVE TRAIN
Transmission Code ............ TY752VB5BA
Transmission Ratios........... 1st 3.166
2nd 1.822
3rd 1.296
4th 0.972
5th 0.738
Reverse 3.416
Final drive 4.444
Front Diff ......................... Open
Centre Diff ....................... Viscous
Rear Diff .......................... Sure track R160 6B
DIMENSION
Wheelbase ........................ 2520mm
Front Track ........................ 1470mm
Rear Track ......................... 1460mm
Weight .............................. 1250kg
COLOURS*
Feather White #30
Active Red #59
Royal Blue Mica #2D
Black Mica #16
WRX C
Launch Date: 7/10/1994 Price: 2,498,000 yen
Applied model code: GC8C48D
SPECIFICATIONS
ENGINE
Engine Code ...................... EJ20GDW4HE
Max. Power Output ........... 260ps/6500rpm
0-60
Wheel Size ........................ 15x6.5JJ
DRIVE TRAIN
Transmission Code ........... TY752VB3FA
2nd 2.062
3rd 1.448
4th 1.088
5th 0.825
Reverse 3.416
Final drive 4.111
DIMENSION
Weight ................................ 1230kg
COLOURS*
Feather White #30
Active Red #59
Black Mica #7A
« แก้ไขครั้งสุดท้าย: ตุลาคม 31, 2010, 11:24:54 pm โดย name_joker »
« ตอบกลับ #3 เมื่อ: ตุลาคม 31, 2010, 11:07:50 pm »
STi Ver. IV
Launch Date: 9/1997 Price: 2,899,000 yen
Applied model code: GCE84ED
SPECIFICATIONS
ENGINE
Engine Type ....................... 1994cc, water cooled, DOHC 16V, Open Deck block, Boxer Master 4.
Rev Limit ........................... 7500rpm
Turbo .................................. RHF5HB
Compression Ratio ............. 8.0
Max Torque ....................... 36.0Kgm/4000rpm
0-60
Rotor Size ........................ 294x24
ABS .................................. 4 Channel ABS
DRIVE TRAIN
Transmission Code ........... TY752VBCAA
Transmission Ratios.......... 1st 3.166
2nd 1.822
3rd 1.296
4th 0.972
5th 0.738
Reverse 3.416
Final drive 4.444
Rear Diff .......................... R160 WF
DIMENSION
COLOURS*
Feather White #30
Active Red #59
Royal Blue Mica #2D
Black Mica #7A
WRX D
Launch Date: 9/9/1996 Price: 2,555,000 yen
Applied model code: GCD848D
SPECIFICATIONS
ENGINE
Engine Code ...................... EJ20KDW6HE
Max Torque ....................... 33.5Kgm/4000rpm
0-60
DRIVE TRAIN
Transmission Code ............ TY752VBCAA
2nd 1.822
3rd 1.296
4th 0.972
5th 0.738
Reverse 3.416
Final drive 4.444
DIMENSION
COLOURS*
Feather White #30
Active Red #59
Royal Blue Mica #2D
Black Mica #16
« แก้ไขครั้งสุดท้าย: ตุลาคม 31, 2010, 11:27:03 pm โดย name_joker »
« ตอบกลับ #4 เมื่อ: ตุลาคม 31, 2010, 11:10:06 pm »
STi Ver. V
Launch Date: 9/1998 Price: 2,919,000 yen
Applied model code: GC8F4ED
SPECIFICATIONS
ENGINE
Engine Type ....................... 1994cc, water cooled, DOHC 16V, Open Deck block, Boxer Phase II.
Engine Code ...................... EJ207DW1PR
Rev Limit ........................... 7900rpm
0-60
DRIVE TRAIN
Transmission Code ........... TY754VBAAA
2nd 1.822
3rd 1.296
4th 0.972
5th 0.738
Reverse 3.416
Final drive 4.444
Front Diff ......................... Open Type
Rear Diff .......................... Sure Track R160 FR
DIMENSION
Overall Length .................. 4350mm
Wheelbase .........................2520mm
Weight ...............................1270kg
COLOURS*
Pure White #1E
Arctic Silver Metallic #92
Cool Grey Metallic#6F
Black Mica #7A
WRX E
Launch Date: 9/1997 Price: 2,569,000 yen
Applied model code: GCE848D
SPECIFICATIONS
ENGINE
0-60
DRIVE TRAIN
2nd 1.822
3rd 1.296
4th 0.972
5th 0.738
Reverse 3.416
Final drive 4.444
DIMENSION
COLOURS*
Feather White #30
Active Red #59
Royal Blue Mica #2D
Black Mica #7A
WRX G
Launch Date: 9/1999 Price: 2,579,000 yen
Applied model code: GC8G48D
SPECIFICATIONS
ENGINE
Engine Code ...................... EJ207DW1KE
Max Torque ....................... 34.5Kgm/4000rpm
0-60
DRIVE TRAIN
2nd 1.822
3rd 1.296
4th 0.972
5th 0.738
Reverse 3.416
Final drive 4.444
DIMENSION
Weight ................................ 1270kg
COLOURS*
Pure White #1E
Black Mica #7A
Cashmere Yellow
Gran Blue Mica
« แก้ไขครั้งสุดท้าย: ตุลาคม 31, 2010, 11:33:54 pm โดย name_joker »
« ตอบกลับ #5 เมื่อ: ตุลาคม 31, 2010, 11:12:43 pm »
STi Ver. VI
Launch Date: 9/1999 Price: 2,919,000 yen
Applied model code: GC8G4ED
SPECIFICATIONS
ENGINE
0-60
DRIVE TRAIN
2nd 1.822
3rd 1.296
4th 0.972
5th 0.738
Reverse 3.333
Final drive 4.444
DIMENSION
COLOURS*
Pure White #1E
Black Mica #7A
Cashmere Yellow
Gran Blue Mica
WRX F
Launch Date: 9/1998 Price: 2,579,000 yen
Applied model code: GC8F48D
SPECIFICATIONS
ENGINE
0-60
DRIVE TRAIN
2nd 1.822
3rd 1.296
4th 0.972
5th 0.738
Reverse 3.416
Final drive 4.444
Rear Diff .......................... Sure Track R160 WF
DIMENSION
COLOURS*
Pure White #1E
Black Mica #7A
« แก้ไขครั้งสุดท้าย: ตุลาคม 31, 2010, 11:31:35 pm โดย name_joker »
« ตอบกลับ #6 เมื่อ: ตุลาคม 31, 2010, 11:18:47 pm »
J D M - "Import" Model Codes Type/Version/HP • 1992 - 1995
GC8A48D.....WRX 4 door / 238
GC8A47D ... WRX Type RA 4 door / 238
GC8B48D ... WRX 4 door / 248
GF8B25D =. WRX 5 door / 218
GC8B47D ....WRX Type RA 4 door / 258
GC8B47D =. WRX Type RA STi V1 4 door / 272
GF8B58D = .WRX 5 door / 218
GF8B58D =. WRX Type RA 5 door / 248
GF8B58D =. WRX STi V1 5 door / 258
GC8C48D = WRX 4 door / 238
• 1995 - 1997
GC8C47D =.WRX STi V1 4 door / 258
GC8C47D = WRX Type RA STi V1 4 door /272
GF8C58D =. WRX 5 door / 218
GC8C4ED =.WRX STi V2 555 4 door /272
GC8C4DD =.WRX Type RA STi V2 / 272
GC8C4DD =.WRX Type RA STi V2 V-Limited / 272
GF8C58D = .WRX STi V2 5 door / 258
GF8C58D = .WRX STi V2 555 5 door / 258
GF8C58P = .WRX 5 door AT / 220
GC8D2DD =.WRX Type R STi 2 door / 278
GC8D48D =,WRX 4 door / 258
GC8D47D . .WRX Type RA 4 door /278
• 1997 - 1998
GC8D4ED = WRX STi V3 4 door / 278
GC8D4ED = WRX STi V3 Type V-Limited 4 door / 278
GC8D4DD = WRX Type RA STi V3 / 278
GF8D58D = WRX 5 door / 238
GF8D5ED = WRX STi V3 5 door / 278
GF8D5ED = WRX STi V3 V-Limited 5 door /278
GF8D58P = WRX 5 door AT / 238
• 1998 - 1999
GC8E2DD = WRX Type R STi V4 2 door /278
GC8E2DD = WRX Type R STi V4 V-Limited 2 door / 278
GC8E2SD = WRX Type R STi Type 22B / 278
GC8E27D = WRX Type RA V-Limited 2 door /278
GC8E48D = WRX 4 door / 248
GC8E47D = WRX Type RA 4 door /278
GC8E4ED = WRX STi V4 4 door /278
GC8E4DD = WRX Type RA STi V4 4 door /278
GC8E4DD = WRX Type RA STi V4 4 door V-Limited / 278
GF8E58D = WRX 5 door / 248
GF8E5ED = WRX STi V4 5 door /278
GF8E58P = WRX 5 door AT /240
GC8F2DD = WRX Type R STi V5 2 door /278
GC8F2DD = WRX Type R STi V5 V-Limited 2 door /278
GC8F27D = WRX Type RA V-Limited 2 door /278
GC8F48D = WRX 4 door /248
• 1999 - 2000
GC8F47D = WRX Type RA 4 door /278
GC8F4ED = WRX Type STi V4 4 door /278
GC8F4DD = WRX Type RA STi V5 4 door /278
GC8F4DD = WRX Type RA STi V5 4 door V-Limited / 278
GF8F58D = WRX 5 door / 248
GC8G2FD = WRX Type R STi V6 Limited / 278
GC8G48D = WRX Type RA 4 door / 278
GC8G47D = WRX Type RA Limited 4 door / 278
GC8G4DD = WRX Type RA STi6 4 door / 278
• WRX Type RA
Race Altered is a lighter weight Impreza generally they come without underseal, radio-cassette, electric windows & sound deadening materials in the cabin. The RA comes with a closed deck block, shorter gearing & rally flap style roof vent.
• Applied VIN Chassis Codes
GF4. = 2.2L Impreza Wagon
GD2. = 2.0L Impreza WRX saloon
GC5. = 1.8L Impreza saloon
GC8. = 2.0L Impreza saloon (Classic)
GF8. = 2.0L Impreza Wagon (Classic)
GDA. = 2.0L Impreza WRX saloon (New Age)
GGA. = 2.0L Impreza WRX Wagon (New Age)
GDB. = 2.0L Impreza WRX STi saloon (New Age)
GGB. = 2.0L Impreza WRX STi wagon (New Age)
GFC. = 2.2L Impreza Wagon
GME. = 2.5L Impreza Coupe
GD7. = 2.5L Impreza WRX STi saloon
GDF. = 2.5L Impreza WRX STi
GM6. = 2.5L Impreza Coupe
• Applied Model Codes (Body)
GC = Impreza saloon ,,(Classic)
GF = Impreza Wagon ,.(Classic)
GM....Impreza Coupe ..(Classic)
GD = Impreza saloon...(New Age)
GG = Impreza Wagon,,(New Age)
• UK Applied Model Codes (Classic)
GC8EK8D = Turbo 4 door
GC8EKFJ = ,Sport 4 door
GF8EKFJ = . Sport 5 door
GC8EK8D = Catalunya
GC8FK8D = Turbo 4 door
GF8FK8D = Turbo 5 door
GC8GK8D = RB5
GC8HK8D = Turbo 4 door
GC8HKED = P1
• Applied Model Codes (New Age)
GDABK8D = WRX
GDBBKKH = WRX STi Prodrive
GDBCKEH = WRX STi
• Applied Engine Codes
EJ-12 = 1189cc FF Drive
EJ-15 = 1493cc FF
EJ-16 = 1597cc AWD
EJ-18 = 1820cc AWD
EJ-20 = 1994cc AWD
EJ-22 = 2212cc AWD
EJ-251 =2457cc AWD
EJ-257 =2457cc AWD
EJ-16 = 1597cc SOHC 16V
EJ-16J =1597cc SOHC 16V
EJ18S =1820cc SOHC 16V
EJ20E =1994cc SOHC 16V
EJ20G =1994cc DOHC 16V Turbo - Found in early model JDM WRXs and STIs
EJ20K ..1994cc DOHC 16V Turbo - Design change from the EJ20G (96-98)
EJ20T =1994cc DOHC 16V Turbo
EJ205.. 1994cc DOHC 16v Turbo - non-JDM
EJ22E= .2212cc SOHC 16V
EJ22T =2212cc SOHC 16V Turbo
EJ22K.. 2212cc DOHC 16V Turbo-found in the 22B
EJ255 =2457cc DOHC 16V Turbo
EJ25T =2457cc DOHC 16V Turbo
EJ257.. 2457cc DOHC 16V Turbo - new age STi
What your Subaru VIN number actually means.
Sample VIN. (UK 2002 WRX) J F 1 G D A K D 3 .2 ..G ..XXXXXX
Digit Number: 1 2 3 4 5 6 7 8 9 10 .11 ..12-17
1. Region: J = Asia
2. Country: 1 & 2 JF = Japan
3. Manufacturer: 2 & 3 F1 = Subaru
4. Series: G = Impreza
5. Body Style: = Saloon
6. Engine Displacement: A = 2.0L
7. Model: K = WRX
8. Restraint Type
9. Check Digit:
10. Year: 2 = 2002
11. Assembly Plant/Transmission Type: G = AWD MT5
12 -17 = 6 Digit Prodution Serial Number
